Creating custom selection scripts
Command
Path
Custom Selection
Tools
Custom selection scripts allow you to select or deselect objects in a file according to specified criteria. No scripting knowledge is necessary.
The layer options must be set to Show/Snap/Modify Others to select objects on another layer.
To create a custom selection script:
Select the command.
The Custom Selection dialog box opens. Select the desired options for the operation.
Parameter
Description
Select
Selects objects matching the specified criteria without affecting the selection status of other objects
Select Only
Selects objects matching the specified criteria and deselects all other objects
Deselect
Deselects objects matching the specified criteria without affecting the selection status of other objects
Execute Immediately
Performs the specified operation immediately upon exiting the dialog box; the operation criteria are not saved for future use
Create VectorScript
Saves the criteria and command options as a VectorScript that can be reused, but does not run the script
Create Python Script
Saves the criteria and command options as a Python script that can be reused, but does not run the script
Specify the criteria for the operation as described in The Criteria dialog box. Click OK.
If you selected one of the script options, you're prompted to select a palette for the script, and then to name the script containing the commands. The script then displays in the specified palette; double-click the script to perform the operation. See Creating and editing script palettes and scripts.
If you selected the Execute Immediately option, the objects are selected or deselected.
Using scripts
Running scripts
